Threads: 4
27.11.2019, 22:23
(This post was last modified: 27.11.2019, 22:24 by Erwin van der Zwart.)
Why do you make it so complex? Just create a scheduler with sunrise and sunset event and use the build-in offset..
PS: You get the error because you use event elements as the final output, use normal elements for the output of the not equal block, and you need to add a timer to your sunrise/sunset element to trigger them on a given interval.
Threads: 1
Dear Erwin, thank you for your reply.
As you suggest, I create two schedulers. One for sunrise and one for sunset.
I would like to energize the sunrise/sunset mode only if the home button is active.
Should i make a fbd script with lock out function so only when the home button is active to run the specific GA from the sunrise/sunset scheduler?
Is there any manual for W4K in order to learn more for the scripts and the fbd, because the manual of homelynk is very poor on scripting.
Threads: 1
Thank you very much. Witch in class training do you mean?
Threads: 4
You have to ask this to SE in your country, i give them on a regular base in the Netherlands, tomorrow i give another one (:
i know our Excellence Center is also giving training for our Global organization, your SE sales rep should be able to give you this info.
What country do you come from?
Threads: 1
Thank you very much Erwin! Greece!
