Threads: 17
Is there a script that can get status out of a Helvar routersystem with HelvarNet?
Try this script to check communication to HelvarNet. It will send query command every 3 seconds. If this works then status map to group address can be implemented.
Resident script, sleep time = 0. Change 192.168.1.1 to HelvarNet router IP. Change 1.1.2.15 to the address of the device you want to query. You will get raw and parsed replies in Logs tab.
Code: if not sock then
ip = '192.168.1.1'
sock = require('socket').udp()
sock:setsockname('*', 60001)
sock:settimeout(1)
ptime = os.time()
function parseitem(res, item)
if item:sub(1, 1) == '@' then
if item:find('=') then
local addr, val = unpack(item:split('='))
res.addr = addr:sub(2)
res.val = val
elseif item:find(':') then
local key, val = unpack(item:split(':'))
res[ key ] = val
function parse(data)
local res = {}
if not data:find('#') then
return
res.type = data:sub(1, 1)
data = data:sub(2, -2)
local items = data:split(',')
for _, item in ipairs(items) do
log(res)
data = sock:receive()
if data then
log(data)
parse(data)
ctime = os.time()
if (ctime - ptime) >= 3 then
ptime = ctime
sock:sendto('>V:1,C:152,@1.1.2.15#', ip, 50001)
Threads: 17
07.05.2020, 08:42
(This post was last modified: 07.05.2020, 08:44 by victor.back.)
(21.04.2020, 14:59)admin Wrote: Try this script to check communication to HelvarNet. It will send query command every 3 seconds. If this works then status map to group address can be implemented.
ip = '192.168.1.1'
sock:settimeout(1)
ptime = os.time()
res.val = val
res[ key ] = val
local res = {}
return
log(res)
if data then
log(data)
parse(data)
ctime = os.time()
ptime = ctime
First thanks for help.
Tried changed the IP and device address as followed but doesnt get any in log or error log. ?
I checked the push message in Helvar designer is set to True.
ip = '192.168.1.14'
sock:settimeout(1)
ptime = os.time()
res.val = val
res[ key ] = val
local res = {}
return
log(res)
if data then
log(data)
parse(data)
ctime = os.time()
ptime = ctime
sock:sendto('>V:1,C:152,@1.14.1.61#', ip, 50001)
Try changing local port from 60001 to 50001. If it still does not work then the example should be modified to use TCP instead of UDP.
Threads: 17
Great! changed the port 50001, and now I get information in log.
Threads: 6
Hi!
This story with Helvar, did you got some results or working solution?
Interested to use LM instead of Helvar BACNET gateway.
