[PRE-RELEASE 3] LogicMachine firmware 2020.07
#41
I am unable to perform the firmware upgrade, not sure what is wrong with my LM4 running i.MX28 CPU, looks that the logs are indicating some filesystem errors:
Sep 18 16:15:42 LogicMachine kern.notice kernel: [ 20.411877] random: nonblocking pool is initialized
Sep 18 16:15:28 LogicMachine user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Sep 18 16:15:28 LogicMachine kern.info kernel: [ 6.740689] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Sep 18 16:15:26 LogicMachine kern.info kernel: [ 5.297110] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Sep 18 16:15:26 LogicMachine kern.info kernel: [ 5.295976] EXT4-fs (mmcblk0p3): recovery complete
Sep 18 16:15:26 LogicMachine user.info sysinit: /dev/mmcblk0p3: ********** WARNING: Filesystem still has errors **********
Sep 18 16:15:26 LogicMachine user.info sysinit: e2fsck: unable to set superblock flags on /dev/mmcblk0p3
Sep 18 16:15:26 LogicMachine user.info sysinit: Run journal anyway? yes
Sep 18 16:15:26 LogicMachine user.info sysinit: Superblock needs_recovery flag is clear, but journal has data.
Sep 18 16:15:26 LogicMachine user.info sysinit: /dev/mmcblk0p3: recovering journal
Sep 18 16:15:26 LogicMachine user.info sysinit: e2fsck 1.44.1 (24-Mar-2018)
Sep 18 16:15:26 LogicMachine kern.info kernel: [ 4.743869] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
Sep 18 16:15:25 LogicMachine kern.info kernel: [ 3.410789] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 3.084580] watchdog timeout 60 seconds
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.873651] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.175997] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.168984] usb 2-1: SerialNumber: 12345678-9012-3456-7890-123456789012
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.168946] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.168884] usb 2-1: New USB device found, idVendor=0658, idProduct=0200
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 1.029903] usb 2-1: new full-speed USB device number 2 using ci_hdrc
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.992137] Freeing unused kernel memory: 140K
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.991353] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.991182] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.988936] EXT4-fs (mmcblk0p2): recovery complete
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.914325] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.914267] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.820560] mmcblk0: p1 p2 p3
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.817422] mmcblk0: mmc0:59b4 00000 7.48 GiB
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.815364] mmc0: new high speed SDHC card at address 59b4
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.812662] mmc0: host does not support reading read-only switch, assuming write-enable
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.807074] Waiting for root device /dev/mmcblk0p2...
Sep 18 16:15:24 LogicMachine kern.err kernel: [ 0.806907] Warning: unable to open an initial console.
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.805415] rtc-ds1307 0-006f: setting system clock to 2020-09-18 16:15:22 UTC (1600445722)
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.798688] NET: Registered protocol family 17
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.774891] mxs-mmc 80010000.ssp: initialized
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.743550] 80010000.ssp supply vmmc not found, using dummy regulator
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.742421] usbcore: registered new interface driver btusb
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.737143] lirc_dev: IR Remote Control driver registered, major 248
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.735726] i2c /dev entries driver
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.734176] rtc-ds1307 0-006f: 64 bytes nvram
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.734058] rtc-ds1307 0-006f: rtc core: registered mcp7941x as rtc0
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.730119] g_ether gadget: g_ether ready
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.730064] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.729533] using random host ethernet address
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.729456] using random self ethernet address
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.729289] usb0: MAC 0a:5a:7c:dd:7e:87
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.728966] usb0: HOST MAC d6:62:69:c8:fc:b1
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.726378] using random host ethernet address
Sep 18 16:15:24 LogicMachine kern.warn kernel: [ 0.726290] using random self ethernet address
Sep 18 16:15:24 LogicMachine kern.info kernel: [ 0.723518] hub 2-0:1.0: 1 port detected
I have also enclosed some images with what I see after trying to upgrade the firmware on my LM4. Basically, the FW version has remained the same as before doing the upgrade.
Does anyone knows why my LM4 does not accepts the new firmware and stays stuck on the older firmware?
(23.09.2020, 16:53)andeug Wrote: Does anyone knows why my LM4 does not accepts the new firmware and stays stuck on the older firmware?
Your card is in read only mode and needs replacement
Thank you, Daniel! Do you know if this is documented somewhere on the forum or in the LM4 instructions/user manual? Can I use any SD/microSD card?
(23.09.2020, 16:57)andeug Wrote: Thank you, Daniel! Do you know if this is documented somewhere on the forum or in the LM4 instructions/user manual? Can I use any SD/microSD card?
https://openrb.com/reflash-logicmachine3...-software/
Any up to 32GB, a SLC or eMLS card is recommended.
To your email:
This image http://dl.openrb.com/recovery.img.gz
Hello everyone,
I have noticed that when importing an ESF file where the datatype is unknown (Dali RGBW 251.600) in my case then the GA is not imported. The problem probably comes from the ETS export to ESF (in ETS this object has the correct datatype assigned and linked to the dali GW) but I am mentioning this in case is related with a bug from the latest firmware. LM5lite FW 20200720.
It's my 1st time to see this so maybe its how LM imports the ESF anyway.
This post can be removed by admin if needed!
You should use KNX project import instead of ESF file
(25.09.2020, 12:19)admin Wrote: You should use KNX project import instead of ESF file
Thank you admin for the quick reply.
Since its a new function I haven't used it yet but will give it a try on my next project. Nice to know!
My customer has an LM5lp. Yesterday he downloaded the software upgrade package on your company's website. The version is 20170620. Now he wants to upgrade to the 2020 version. But after entering System config, there is no response after clicking to upgrade firmware, nor after refreshing or restarting. How can I solve this problem?
Might be a micro SD card issue. Get a new industrial or high endurance micro SD (at least 1GB). Make a backup from LM. Then follow this guide on how to flash recovery firmware: https://openrb.com/reflash-logicmachine3...-software/
Before doing anything with the SD card, try clearing browser cache as i have seen this before after a FW upgrade..
(16.10.2020, 07:17)管理员 Wrote: 可能是micro SD卡问题。获取新的工业或高耐久性micro SD(至少1GB)。从LM进行备份。然后按照以下有关如何快速恢复固件的指南进行操作:https://openrb.com/reflash-logicmachine3-and-streaming-player-software/
Ťhanks,I'll try it.
I worked with LM5. Exported some groups from ETS, and than added many manually. Now group adding not so convenient, is possible delete them or use filter. May be developers can include in next release possibility of adding empty groups automatically - as example from 1/1/10 add 10 groups, and show for them data type - as example boolean? After that just name should be added - faster configuration..
Also working with scheduler - may be possible to add to scheduler such option as "period"? A little complicated, but idea - as example it can be started at 9:00 for 2 hours. Status can be always active or not active during these 2 hours.. depending of settings. Will be easier work as example with light control.
I have an old LM2, labeled LM2 interface 2. The displayed firmware version is 20141127.
I tried to download the new LM2 firware from the top of this thread, but when i try to install with the function "Systemconfiguration, System, Upgrade firmware", the upgrade prosess seems to start, but the version remains the same after rebooting.
When trying to use the function "Utilities, Install updates", i got the message "Update package file is invalid".
I have also made a factory reset.
In case my LM2 unit is not supported anymore, is there any newer firmvare available?
Send a screenshot from System config->Status->System status -> Partitions
(27.10.2020, 11:16)Daniel. Wrote: Send a screenshot from System config->Status->System status -> Partitions
This is LM version is not supported anymore. The latest firmware for it is 20181002: http://dl.openrb.com/lm-18-at91/20181002.img
Hi, after updating the firmware, the information from the modbus table has stopped updating. The test and polling show that the RS-485 interface is working, but there is no connection between the KNX objects and the modbus. I ask for help)
Do you have anything in the standard Error log and Modbus Error log?
I've noticed strange behavior of "Page" counter in "Objects" tab. See the video at this link (google drive) https://drive.google.com/file/d/1QlHWnO7...p=drivesdk
and watch Page area.
