27.08.2020, 10:43
since i updated to the new iOS App i cant recive any Push notifications. Even when i go to LM Cloud app.
this is the Device ID after i updated to the new iOS App.
This is the Errormessage when i send a Push direct from the LM Cloud app.
is there any documentation for the new App how to set up push notifications ?
{length=32,bytes=0xdc8a7a00d8a54ed8da242445e0a80034...c0d2593b632bbee0}
{"line":77,"code":0,"file":"\/var\/www\/cloud.logicmachine.net\/vendor\/duccio\/apns-php\/ApnsPHP\/Message.php","type":"ApnsPHP_Message_Exception","stack-trace":["#0 \/var\/www\/cloud.logicmachine.net\/vendor\/duccio\/apns-php\/ApnsPHP\/Message.php(63): ApnsPHP_Message->addRecipient('{length=32,byte...')","#1 \/var\/www\/cloud.logicmachine.net\/backend\/controllers\/MosaicapiController.php(214): ApnsPHP_Message->__construct('{length=32,byte...')","#2 \/var\/www\/cloud.logicmachine.net\/backend\/controllers\/MosaicapiController.php(77): backend\\controllers\\MosaicapiController->actionPush()","#3 [internal function]: backend\\controllers\\MosaicapiController->actionIndex()","#4 \/var\/www\/cloud.logicmachine.net\/vendor\/yiisoft\/yii2\/base\/InlineAction.php(57): call_user_func_array(Array, Array)","#5 \/var\/www\/cloud.logicmachine.net\/vendor\/yiisoft\/yii2\/base\/Controller.php(157): yii\\base\\InlineAction->runWithParams(Array)","#6 \/var\/www\/cloud.logicmachine.net\/vendor\/yiisoft\/yii2\/base\/Module.php(528): yii\\base\\Controller->runAction('index', Array)","#7 \/var\/www\/cloud.logicmachine.net\/vendor\/yiisoft\/yii2\/web\/Application.php(103): yii\\base\\Module->runAction('mosaicapi\/index', Array)","#8 \/var\/www\/cloud.logicmachine.net\/vendor\/yiisoft\/yii2\/base\/Application.php(386): yii\\web\\Application->handleRequest(Object(yii\\web\\Request))","#9 \/var\/www\/cloud.logicmachine.net\/backend\/web\/index.php(18): yii\\base\\Application->run()","#10 {main}"],"name":"Exception","message":"Invalid device token '{length=32,bytes=0xdc8a7a00d8a54ed8da242445e0a80034...c0d2593b632bbee0}'"}
