Threads: 29
we've in germany a new popular internet provider for fibre channel internet (deutsche glasfaser) an he provids only DS-Lite, what means you get an native ipv6 support without usable ipv4 adress for incoming traffic.
What works is to use the ipv6 adress, but for this it's necessary that the LM oder SL gets an ipv6 adress.
Is there an solution for that?
Thx and regards
Habib
Threads: 29
Hi admin,
is zerotier possible with spaceLYnks?
I understand it in that way, that we need a new firmware with zerotier support?
Threads: 31
For now not and probably will not be. SE is extremely cautious when it comes to remote access and specially with 3rd party cloud.
Threads: 31
For now I have only LM Lite beta fw. Later all of them will get new fw.
Threads: 29
Is this a matching LM for your Beta Fw?
Threads: 31
The FW would run on it but whatever you have as extension will not work. Which LM is it?
Threads: 31
You didn't get it, LM internally is build from 2 parts, the base which is LM lite and additional card which can be canX, or KNX choke. The full name in on the side label of LM.
Threads: 31
OK so the CANx and the top rs485 port will not work. Do you want to try? You will be able to install the correct fw later.
Threads: 31
Threads: 29
Wow, so easy... it works. thank you. I hope it will be by default in the next releases
Threads: 31
Hi, I talked to SE and they are evaluating this solution right now. There was no decision yet. Request this to SE sales for extra push
