Bug in SL 2.5.1?
I want to simulate an switch action on my visualisation and use for that a SpaceLynk with firmware 2.5.1 (the last one)
What I want to write is, if some value bigger than 0 write in the groupadress 1/1/7 true, or if it 0 (zero) than set the value to false....
nothing complicated, or?
But I get a strange behaviour. The script is working but it will repeats 7 times... everytime...
I tried the same scipt on my LM at home, and there the script works like expected...???
spaceLYnk
Logicmachine
You probably have KNX loop, disable KNX IP and check again
Argh.... ;-) that was the issue  Angel
I forgot the last Hw Changes on my testboard
Thx Daniel
