to pass credentials in URL
Hi, since to pass credentials in url (i.e. http://user:password@example.com) is deprecated and not working anymore in the most of web browser, is still possible to pass them in base64 encoding (in the example: dXNlcjpwYXNzd29yZA==) like we do for a webcam string?
What is the exact format of the URL?
I tried http://example.com/?auth=dXRlbnRlcDpVdGVudGUwMQ==
but it still ask me credentials....
thanks
peppe
Passing credentials like this is not a standard feature, the website must support it otherwise it will not work.
(15.01.2021, 15:12)admin Wrote: Passing credentials like this is not a standard feature, the website must support it otherwise it will not work.
Hi Admin,
If a webcam doesn't have in the URL the possibility to pass credentials, is there a way to connect with it?
An example hikvision has not the credentials in the URL and anonymous user in the features.
Is there a way to integrate it?
Best regards Cristian
You will probably need an external device like Raspberry Pi to act a proxy for the stream without credentials.
(12.01.2022, 14:07)admin Wrote: You will probably need an external device like Raspberry Pi to act a proxy for the stream without credentials.
Thanks for the answer I will check on google some example.
