LM app in android
I have a question about app.
I have a subdomain (lm.mydomain.com) redirected to my lan LM. https://lm.mydomain.com --> http://192.168.1.200 (LM internal IP)
It works perfectly i I do that in a web browser and I have protected by SSL but if I put this domain in app, it doesn´t work. Any idea??
As far I remember the local device use only http. Try remote, set custom and put it there.
Local device allow https, but aniway I redirect by inverse proxy, from external https to internal http.
With cusom remote it works
You didn't get it. Android app when local(Home) connection is used it use only HTTP. The Remote use only HTTPS try putting any page which has valid SSL cert it will open.
(12.03.2021, 17:26)Daniel. Wrote: You didn't get it. Android app when local(Home) connection is used it use only HTTP.  The Remote use only HTTPS try putting any page which has valid SSL cert it will open.
Ok, i understand it. But with remote i only can add one address, and I can´t open it automaticaly when I open app.
Remote will open automatically when your mobile will be on data. Sorry the app was designed for mosaic in mind.
