This is for widgets done in the Widget creator. You can export a custom widget in JSON format.
Threads: 32
06.09.2021, 09:53
(This post was last modified: 06.09.2021, 09:53 by DGrandes.)
Hi!,
I´m trying to work with Mosaic Thermostat but I have some questions:
- I´ve seen that sending object is diferent from ACK object and I´m working with SE Multitouch thermostat.
- I´m trying to do custom thermostat with widget creator but there isn´t any button that send value with status object.
- Isn´t there any way to lock thermostat when is in frost mode? when i open a window? Like se multitouch thermostat works?
Threads: 31
You should be able to use build in Thermostat as it was designed by SE with they specific thermostat modes.
The Status object fallow this..
Threads: 42
Hello, I would like to display a temperature value with at least one decimal place. With the elements available in the Widget editor I don't see a way to achieve it.
Threads: 31
Do you use the latest version of Mosaic beta? As far I remember this correction is there
Threads: 31
We looked in to this and it seems there is bug when sub-type like 9.001 is used. This will be fixed in next version. As quick work around just set dpt to 9 and it will work correct.
Threads: 31
This bug was fixed in latest Mosaic, just update.
Threads: 42
Hello, in mosaic beta when selecting a widget to be displayed on the main or floor screen, the accesses to floors or rooms disappear.
Does this happen using admin user or normal user? I cannot reproduce this locally. Can you provide more detailed steps or even better a backup JSON file where this issue is present?
Can you send Mosaic backup JSON file via PM?
Thanks. This is actually by design. You need to enable both "Show widgets on the Main page" and "Show navigation on the Main page" in "Settings & themes".
