Threads: 60
It would be nice when we create an event based script, that there is the checkbox "Execute on group read:", so that we can enable this straightaway. This would save time and prevent mistakes.
Thanks,
Roger
Threads: 3
Don't know I you seen it but
in the Last FW, hL1.5 / sL1.2, you have the 'run script' function inside the editor that allow you to execute the script with a specific value.
I'm not sure it's exactly what you want, but it should do the trick.
Enabling exec on read by default will lead to more errors as most users won't bother with checking event.type in their scripts.
Threads: 8
28.06.2016, 14:29
(This post was last modified: 28.06.2016, 15:15 by Erwin van der Zwart.)
Hi Roger
Why do you need it?
I have seen a huge amount of HL/SL projects and the only time i have seen it used is for 3th party app where you need the objects respond like a object server.
I agree with admin as it would bring a lot more support for a almost never used feature.
Threads: 60
Hi Erwin,
Yes I need to make the objects respond like an object server. Then simply make this option available to be enabled in the lm settings screen. so by default it won't be available, but for the installers that do need it, then it can be enabled. Then everyone is happy.
Thanks,
Roger
