Sending email
Big Grin
After some testing I discovered that when sending an email to multiple recipients the 'to' variable wasn't being converted to an table.  It would create a table but only contained one row.  Below is a revised version of the send email script.  Make sure that each recipient is separated with a comma,  ie...  mail('your@first.com, your@second.com, your@third.com', 'some subject', 'some message')
In addition to this, when you want to send via an email server that does not require ssl, just comment out the line, secure='sslv23'
Thanks,
Roger
-- send an e-mail
function mail(to, subject, message)
 -- make sure these settings are correct
 local settings = {
   from = 'example@gmail.com',
   -- smtp username
   user = 'example@gmail.com',
   -- smtp password
   password = 'mypassword',
   -- smtp server
   server = 'smtp.gmail.com',
   -- smtp server port
   port = 465,
   -- enable ssl, required for gmail smtp
   secure = 'sslv23',
 local smtp = require('socket.smtp')
 if type(to) ~= 'table' then
    to = string.split(to,', ')
 for index, email in ipairs(to) do
   to[ index ] = '<' .. tostring(email) .. '>'
 -- message headers and body
 settings.source = smtp.message({
   headers = {
     to = table.concat(to, ', '),
     subject = subject,
     ['Content-type'] = 'text/html; charset=utf-8',
   body = message
 -- fixup from field
 settings.from = '<' .. tostring(settings.from) .. '>'
 settings.rcpt = to
 return smtp.send(settings)
