change the opacity of a text
hello
I used this JS code to change the objects to read only and change the opacity, but it didnt change the opacity of a text
how to make it work in text also
$(function(){   grp.listen('32/1/1', function(object) {      if (object.value == true ) {         $(".lockbyknx").addClass("item-read-only");          $(".lockbyknx").find('img').css("opacity", 0.5);      } else if (object.value == false ) {         $(".lockbyknx").removeClass("item-read-only");          $(".lockbyknx").find('img').css("opacity", 1);      }   }, true); // set to true to send on same value });
Best Regards,
Custom JS:
$(function(){   grp.listen('32/1/1', function(object) {     $(".lockbyknx").toggleClass("item-read-only", object.value == true);   }, true); // set to true to send on same value });
Custom CSS:
.item-read-only {   opacity: 0.5 !important; }
Thanks admin
But it changed the opacity of all read only values
I want to change the opacity of values with "lockbyknx"
regards,
edit: I changed the CC
/* Change Opacity*/ .lockbyknx {   opacity: 0.3 !important; }
Best Regards,
Use this:
.lockbyknx.item-read-only {   opacity: 0.5 !important; }
(18.11.2021, 12:02)admin Wrote: Use this:
thanks admin
Best Regards,
How can I remove the + and - button from a direct input box ?
This will hide buttons from all input boxes:
.control-spinner .btn { display: none; }
