25.01.2022, 10:15
Yes but it is only available in imx6 devices
[RELEASE] LogicMachine firmware 2021.12
25.01.2022, 10:15
27.01.2022, 10:33
(This post was last modified: 27.01.2022, 10:45 by Thomas.
Edit Reason: System log attached
I'm not sure but it looks like there's a booting sequence issue in the new firmware. KNX interface starts before SD card is ready or something similar. What I've done: 1. I backed up LM1 2. I restored the backup at LM2 Then after boot I got "Cannot open user script" error in error log (see the picture below). System log attached ( time in system log seems to be in UTC)
27.01.2022, 11:27
Send your backup to PM to check. Did you try to make new backup from first LM?
28.01.2022, 13:41
Group monitor starts slightly faster then the scripts are ready. It was like that since the beginning. You see it now as CPU is faster
![]() We will look in to it when working on new fw.
10.02.2022, 08:41
I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link : LM5 Lite (3 DIN units)
10.02.2022, 10:18
(10.02.2022, 08:41)mkaymak Wrote: I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link : LM5 Lite (3 DIN units) This is custom device done on request. Ask your distributor for the firmware.
14.05.2022, 12:39
What is the latest FW for LM5p2-KC ?
16.05.2022, 08:02
LM5 KC belongs to the category LM5 Lite + Ext (4 or 6 DIN units) You can see this described in the fw upgrade part
https://forum.logicmachine.net/showthread.php?tid=3755
30.05.2022, 12:25
I have a LM4 when try to upgrade firmware the loading page counts from 300 to 0 then device restarts with old firmware again.What should I do ?
30.05.2022, 12:33
Most probably the SD card is in read-only state and must be replaced. See this for more info: https://openrb.com/reflash-logicmachine3...-software/
« Next Oldest | Next Newest »
