[RELEASE] LogicMachine firmware 2021.12
#21
Yes but it is only available in imx6 devices
I'm not sure but it looks like there's a booting sequence issue in the new firmware. KNX interface starts before SD card is ready or something similar.
What I've done:
1. I backed up LM1
2. I restored the backup at LM2
Then after boot I got "Cannot open user script" error in error log (see the picture below).
System log attached ( time in system log seems to be in UTC)
Send your backup to PM to check. Did you try to make new backup from first LM?
Group monitor starts slightly faster then the scripts are ready. It was like that since the beginning. You see it now as CPU is faster Smile This does not affect normal operation.
We will look in to it when working on new fw.
I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link :  LM5 Lite (3 DIN units)
(10.02.2022, 08:41)mkaymak Wrote: I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link :  LM5 Lite (3 DIN units)
This is custom device done on request. Ask your distributor for the firmware.
What is the latest FW for LM5p2-KC ?
LM5 KC belongs to the category LM5 Lite + Ext (4 or 6 DIN units) You can see this described in the fw upgrade part
https://forum.logicmachine.net/showthread.php?tid=3755
I have a LM4 when try to upgrade firmware the loading page counts from 300 to 0 then device restarts with old firmware again.What should I do ?
Most probably the SD card is in read-only state and must be replaced. See this for more info: https://openrb.com/reflash-logicmachine3...-software/
