[RELEASE] LogicMachine firmware 2021.12
#21
Yes but it is only available in imx6 devices
I'm not sure but it looks like there's a booting sequence issue in the new firmware. KNX interface starts before SD card is ready or something similar.
What I've done:
1. I backed up LM1
2. I restored the backup at LM2
Then after boot I got "Cannot open user script" error in error log (see the picture below).
System log attached ( time in system log seems to be in UTC)
Send your backup to PM to check. Did you try to make new backup from first LM?
Group monitor starts slightly faster then the scripts are ready. It was like that since the beginning. You see it now as CPU is faster Smile This does not affect normal operation.
We will look in to it when working on new fw.
I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link :  LM5 Lite (3 DIN units)
(10.02.2022, 08:41)mkaymak Wrote: I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link :  LM5 Lite (3 DIN units)
This is custom device done on request. Ask your distributor for the firmware.
What is the latest FW for LM5p2-KC ?
LM5 KC belongs to the category LM5 Lite + Ext (4 or 6 DIN units) You can see this described in the fw upgrade part
https://forum.logicmachine.net/showthread.php?tid=3755
I have a LM4 when try to upgrade firmware the loading page counts from 300 to 0 then device restarts with old firmware again.What should I do ?
Most probably the SD card is in read-only state and must be replaced. See this for more info: https://openrb.com/reflash-logicmachine3...-software/
Hi, how to find hardware/firmware version if it's too old? I need to make an upgrade as I believe it's a bit old now.
I found 20170620 in the LogicMachine > Utilities > Install Updates > at the bottom bar.
Version: 20170620       CPU/IO: 0.14 0.18 0.25, Memory: 34%, KNX/TP: OK
That's the only information I have in the update firmware menu.
Upgrade firmware
Firmware fileNo file chosen
Warning: firmware downgrade is not supported.
It will take about 5 minutes for upgrade to complete. All config files will be kept unchanged. Do not unplug your device while upgrade is in progress!
Information from system status menu:
CPU model
ARM926EJ-S rev 5 (v5l)
Linux kernel version
4.4.73
Run this script once and post what you get in Logs tab:
log(io.readfile('/proc/device-tree/model'))
(15.07.2022, 12:48)admin Wrote: Run this script once and post what you get in Logs tab:
* string: i.MX28 LM2i
Use this FW: https://dl.openrb.com/lm-21-mxs/lm2i-20211215.img
(18.07.2022, 06:23)admin Wrote: Use this FW: https://dl.openrb.com/lm-21-mxs/lm2i-20211215.img
Thank you.
I have another LogicMachine with the following details:
HW: LM2i (i.MX6)
SW: 20180822
Should I use https://dl.openrb.com/lm-21-mxs/lm2i-20211215.img firmware despite that it has another CPU, but not i.MX28? Just wanted to understand the idea.
Reply from the command log(io.readfile('/proc/device-tree/model')) if needed:
* string: i.MX6UL LM2i
For imx6 use this firmware: https://dl.openrb.com/lm-21-imx6/lm2i-20211215.img
