25.01.2022, 10:15
Yes but it is only available in imx6 devices
[RELEASE] LogicMachine firmware 2021.12
25.01.2022, 10:15
27.01.2022, 10:33
(This post was last modified: 27.01.2022, 10:45 by Thomas.
Edit Reason: System log attached
I'm not sure but it looks like there's a booting sequence issue in the new firmware. KNX interface starts before SD card is ready or something similar. What I've done: 1. I backed up LM1 2. I restored the backup at LM2 Then after boot I got "Cannot open user script" error in error log (see the picture below). System log attached ( time in system log seems to be in UTC)
27.01.2022, 11:27
Send your backup to PM to check. Did you try to make new backup from first LM?
28.01.2022, 13:41
Group monitor starts slightly faster then the scripts are ready. It was like that since the beginning. You see it now as CPU is faster
![]() We will look in to it when working on new fw.
10.02.2022, 08:41
I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link : LM5 Lite (3 DIN units)
10.02.2022, 10:18
(10.02.2022, 08:41)mkaymak Wrote: I couldnt updated my Logic Machine 5 Lite .Because current sw doesn't run Cloud app.Used this link : LM5 Lite (3 DIN units) This is custom device done on request. Ask your distributor for the firmware.
14.05.2022, 12:39
What is the latest FW for LM5p2-KC ?
16.05.2022, 08:02
LM5 KC belongs to the category LM5 Lite + Ext (4 or 6 DIN units) You can see this described in the fw upgrade part
https://forum.logicmachine.net/showthread.php?tid=3755
30.05.2022, 12:25
I have a LM4 when try to upgrade firmware the loading page counts from 300 to 0 then device restarts with old firmware again.What should I do ?
30.05.2022, 12:33
Most probably the SD card is in read-only state and must be replaced. See this for more info: https://openrb.com/reflash-logicmachine3...-software/
15.07.2022, 12:16
Hi, how to find hardware/firmware version if it's too old? I need to make an upgrade as I believe it's a bit old now.
I found 20170620 in the LogicMachine > Utilities > Install Updates > at the bottom bar. Version: 20170620 CPU/IO: 0.14 0.18 0.25, Memory: 34%, KNX/TP: OK That's the only information I have in the update firmware menu. Upgrade firmware Firmware fileNo file chosen Warning: firmware downgrade is not supported. It will take about 5 minutes for upgrade to complete. All config files will be kept unchanged. Do not unplug your device while upgrade is in progress! Information from system status menu: CPU model ARM926EJ-S rev 5 (v5l) Linux kernel version 4.4.73
15.07.2022, 12:48
Run this script once and post what you get in Logs tab:
Code: log(io.readfile('/proc/device-tree/model'))
18.07.2022, 05:28
18.07.2022, 06:23
Use this FW: https://dl.openrb.com/lm-21-mxs/lm2i-20211215.img
(18.07.2022, 05:28)4likes Wrote:(15.07.2022, 12:48)admin Wrote: Run this script once and post what you get in Logs tab: (18.07.2022, 06:23)admin Wrote: Use this FW: https://dl.openrb.com/lm-21-mxs/lm2i-20211215.img Thank you. I have another LogicMachine with the following details: HW: LM2i (i.MX6) SW: 20180822 Should I use https://dl.openrb.com/lm-21-mxs/lm2i-20211215.img firmware despite that it has another CPU, but not i.MX28? Just wanted to understand the idea. Reply from the command log(io.readfile('/proc/device-tree/model')) if needed: * string: i.MX6UL LM2i
21.07.2022, 06:46
For imx6 use this firmware: https://dl.openrb.com/lm-21-imx6/lm2i-20211215.img
