scripting and using tags
My question is,
what is the best place to place the script.
i have some scripts what i use for lights and blinds.
at the moment i placed the scripts on the triggers like 'light sensor outside'.
But now i think it is better to place the script on the action, like the groupadress of the blinds.
because if i place the scripts in the trigger, and i have multiple scripts for the blinds, i dont know where to look by a fault or changing.
My question is, where do you place the scripts, by trigger or by action? or is there a better solution?
is there a maximum of tags i can use in total or by 1 groupadress?
You can run script bu start-up, event(single group, tag), resident(run it every X seconds) or scheduled. Which one you use it depends of your script. Not possible to recommend anything from your description.
Tags are not restricted.
Thanks Daniel.
