Create Schedule by Script
I need to create a lot of schedules and I have not found to do it by script in the forum. Is that possible?
Thanks!!
It's possible to do via db queries. The easiest approach is to duplicate existing schedule and change the mapped object. I can provide an example if this works for you.
(04.01.2022, 16:21)admin Wrote: It's possible to do via db queries. The easiest approach is to duplicate existing schedule and change the mapped object. I can provide an example if this works for you.
Ok thanks!! Could you provide me the example?
Use this function to duplicate a scheduler.
Arguments:
1. id - source scheduler ID
2. address - object to map the new scheduler to
3. name - new scheduler name (optional)
function copyscheduler(id, address, name)
  local scheduler = db:getrow('SELECT * FROM schedulers WHERE id=?', id)
  local events = db:getall('SELECT * FROM scheduler_events WHERE scheduler=?', id)
  if scheduler then
    scheduler.id = nil
    scheduler.name = name or (scheduler.name .. ' copy')
    scheduler.object = buslib.encodega(address)
    db:insert('schedulers', scheduler)
    local newid = db:getlastautoid()
    for _, event in ipairs(events) do
      event.id = nil
      event.scheduler = newid
      db:insert('scheduler_events', event)
  io.writefile('/tmp/lm-scheduler-clear', '')
-- duplicate scheduler ID 1, map it to 1/1/1 and set name to 'test2'
copyscheduler(1, '1/1/1', 'test2')
