Export Access Logs
I would like to export the Wiser's Access Logs. Is this possible?
Use this to export to CSV. Then you can upload it to FTP, send via e-mail etc.
rows = {
  '"date","login","ip","failed"'
items = db:getall('SELECT * FROM user_logs ORDER BY id DESC')
for _, item in ipairs(items) do
  date = os.date('%Y.%m.%d %H:%M:%S', item.created)
  failed = toboolean(item.failed)
  rows[ #rows + 1 ] = string.format('%q,%q,%q,%q',
    date,
    item.login or '?',
    item.ip or '?',
    failed and 'yes' or 'no'
csv = table.concat(rows, '\n')
excellent! thank you very-very much
