Threads: 35
New Alexa is live
The new version is using our new cloud, additionally we added new skill for the blinds. You can ask to Open/Close or Set to level. You can also ask Alexa, Is the 'blind name' open?
To use new skill you must update firmware and use New Alexa app from our store. You also must use new cloud
https://remote.logicmachine.net/user for the account linking. The old user will not work, new must be created.
How to use new cloud can be seen here:
The old Skill has been changed to Hidden state. It means that existing users can still keep using it as long no changes will be needed. Once account linking will be needed then new app and new cloud must be used. We will close down old Cloud at some point so we strongly recommend to all customers to port to new cloud. The old cloud will be phased out due to security concerns.
Threads: 68
Hi, I've some questions about this:
- When updating from old version to new one, all devices and skills are mantained?
- Alexa app configuration is stored inse a project backup? If not how can we backup it?
Skills are maintained but the structure is changed so it won't be possible to use this configuration with the old app. All app configuration is included in the backup.
Threads: 35
From old app to new configuration will be preserved.
Threads: 42
The configuration is kept in the new version. You will also have to search the Alexa app (amazon) for the LogicMachine Skill for the new Cloud and perform the device search. In my case, I have had some problems with thermostat type devices, having to remove them and search for them again.
Threads: 35
The problem here is that Amazon never created command for blinds and we created it manually by using semantics. Most likely they do not translate such commands. I'm not sure if we can do anything here. The blind works as you need, 0 is open and 100 is closed.
Threads: 3
When you use the German Language you have to say "öffnen" and "schließen".
At the Beginning of the new skill i allso struggled with the commands.
Threads: 8
With the new APP, if I uninstall and install the Logic Machine skill, will I have the duplicate devices in the Alexa APP?
If I have to do a search for devices and they are duplicated, the routines won't work, right?
thanks
Threads: 35
Yes, you must delete the duplicate ones in Alexa app or on the amazon website.
Threads: 4
Hi, I configured Alexa a week ago for opening closing one of my locks and it worked fine for a few days. However yesterday suddenly I had an issue that commands were not getting through anymore to the LM. Alexa still recognized the command and confirmed the action of opening and closing a lock (including "hang on"), however nothing actually happened with my lock. After configuring and cloud syncing once more with the LM-Alexa app it started working again. Somehow it seemed that the LM-cloud configuration got lost. Is this recognized? What could be causing this, and how to prevent it towards the future?
Threads: 35
What do you have in logs in LM cloud app?
Threads: 4
Problem started 21 sept. Today solved with syncing again. See log below.
2022.09.22 11:09:38 config sync finished for trends
2022.09.22 11:09:38 config sync finished for users
2022.09.22 11:09:37 config sync finished for objectnames
2022.09.22 11:09:37 config sync finished for objects
2022.09.22 11:09:37 config sync finished for mosaic
2022.09.22 11:09:36 config sync finished for alexa
2022.09.21 14:15:31 connection OK
2022.09.21 14:15:18 error: pre-connect failed - Operation timed out, code 14
2022.09.21 14:13:02 error: disconnected - Unknown reason, code 7
2022.09.18 23:27:46 config sync finished for trends
2022.09.18 23:27:39 config sync finished for users
2022.09.18 23:27:30 config sync finished for objectnames
2022.09.18 23:27:21 config sync finished for objects
2022.09.18 23:27:15 connection OK
2022.09.18 23:27:11 connection started
Threads: 35
Do you use latest LM cloud app and the firmware?
Threads: 35
In the app store
Threads: 35
No it is quite old one, press the green button on the right to update.
