Old Cloud closing down
Dear customers
We worked hard to migrate all cloud services from cloud.logicmachine.net to remote.logicmachine.net. Every possible solution is already working on our new secure cloud and we kindly asking you to migrate to the new cloud ASAP.
The old Cloud is planned to be shut down on the 1st of September 2022!
Mosaic3.0 integration: https://forum.logicmachine.net/showthrea...9#pid21069
New Alexa: https://forum.logicmachine.net/showthread.php?tid=3964
Push notifications: https://forum.logicmachine.net/showthread.php?tid=1083
Apologies for any inconveniences this might cause!
I have been using Mosaic 2.0 to be able to use the Logicmachine app for my Wiser for KNX setup with HomeLynk as it is so much better than the Wiser app. Obviously Wiser does not provide Mosaic 3.0 at this point. Any possibility to get the newest IPK for Mosaic 3.0 and the new alexa app or is there anyone here that can tell if these will be available for wiser?
Wiser Touch app is based on Mosaic 3.0 and has Alexa built-in using Schneider cloud.
Thanks for your reply. I am already using this approach for alexa (even though having lots of issues which i am in contact with Schneider support right now). Nevertheless my core intention is to be able to continue to use Logicmachine Android app instead of Wiser as it is better to use. With shutdown of cloud.logicmachine.net this will no longer work due to not having mosaic 3 on wiser. I know it is not actively supported but was hoping for a way how i can continue using this app.
We are not phasing out Mosaic only old cloud, This will not affect android app.
Hello, I would like to comment on a couple of complaints that my client tells me.
1-After the Mosaic update the background image disappears with cloud access.
2-From the cloud, remembering the password for 90 days does not work.
1. Which background images exactly? Custom or built-in ones? Can you provide an example?
2. It won't work if the client IP address changes. You can use LM mobile app which does not have this limitation.
