User Access Log on Vis
Hi, is there a way to display the user access logs in a frame on a vis page.
Only want to show user accounts and exclude ADMIN logins
Via .lp file:
<!DOCTYPE html>
<html>
<head>
  <meta charset="UTF-8">
  <link rel="stylesheet" href="/apps/css/bootstrap.css">
</head>
<body>
<table class="table table-striped">
<tr>
  <th>Date/time</th>
  <th>Login</th>
  <th>Name</th>
  <th>IP</th>
</tr>
require('apps')
items = db:getall([[
  SELECT user_logs.*, users.name
  FROM user_logs
  JOIN users ON user_logs.login=users.login
  ORDER BY user_logs.id DESC
  LIMIT 50
for _, item in ipairs(items) do
  cls = toboolean(item.failed) and 'danger' or 'success'
  datetime = os.date('%Y.%m.%d %H:%M:%S', item.created)
<tr class="<?=cls?>">
  <td><?=datetime?></td>
  <td><?=escape(item.login)?></td>
  <td><?=escape(item.name)?></td>
  <td><?=escape(item.ip)?></td>
</tr>
<? end ?>
</table>
</body>
</html>
(06.05.2022, 08:26)admin Wrote: Via .lp file:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
<tr>
  <th>Date/time</th>
  <th>Login</th>
  <th>Name</th>
  <th>IP</th>
</tr>
require('apps')
  FROM user_logs
  LIMIT 50
</tr>
<? end ?>
</table>
</body>
</html>
 Many thanks for your help
Hello
how does the full code looks like?
Best Regards,
It is the full code (:
(07.05.2022, 18:22)Erwin van der Zwart Wrote: It is the full code (:
Aha
Seems I miss how to use it Smile
should I have something like this at the beginning or its done in another way
dst = '/www/user/accesslog.lp'
io.writefile(dst, [[..... accesss log code....
Best Regards,
Well this code is enabling you to automatically write it to a file on the FTP server, but you could have also just manually upload the code as a .lp file to the FTP server...
