Trend Logs (Max, Min Average)
Hi, is it possible to get the Max, Min and Average values ( all stored data) from each trend name so that they can be added to vis.
Trend Logs
1) Power DB1 : max 2/3/10 min 2/4/10 average 2/5/10
2) Power DB2 : max 3/3/10 min 3/4/10 average 3/5/10
3) Power DB3 : max 4/3/10 min 4/4/10 average 4/5/10
4) Lighting DB1 : max 5/3/10 min 5/4/10 average 5/5/10
This example will calculate min/max/average for the past year data. Keep in mind that this is rather CPU and memory intensive calculation so it's not recommended to run it too often.
require('trends')
trends.NaN = 0 / 0
dates = {}
dates['start'] = os.date('*t')
dates['start'].year = dates['start'].year - 1
dates['end'] = os.date('*t')
values = trends.fetch('TREND_NAME_HERE', dates)
min, max, sum, cnt = math.huge, -math.huge, 0, 0
for _, value in ipairs(values) do
  if value == value then
    min = math.min(min, value)
    max = math.max(max, value)
    sum = sum + value
    cnt = cnt + 1
avg = sum / math.max(1, cnt)
log(min, max, avg)
(09.05.2022, 08:11)admin Wrote: This example will calculate min/max/average for the past year data. Keep in mind that this is rather CPU and memory intensive calculation so it's not recommended to run it too often.
require('trends')
trends.NaN = 0 / 0
dates = {}
    sum = sum + value
    cnt = cnt + 1
log(min, max, avg)
Thank you once again.
