Status of all addresses inside of a middle group
Hi! I am new to LUA and the logic machine and would like to see if you can help me.
I have all the windows and door sensors under the group addresses 6/3 and I would like to create a function to check the status (1 bit) of the addresses in it so I can identify how many doors or windows are open and return the name of them.
I saw some examples of creating arrays to input all the addresses manually and then go through all of them with a for or similar but I wonder whether there is a way to automate it a bit more.
Thank you!!
You can use tags like in this example: https://forum.logicmachine.net/showthrea...0#pid14510
(10.01.2023, 10:44)admin Wrote: You can use tags like in this example: https://forum.logicmachine.net/showthrea...0#pid14510
Thank you for your prompt response!!
I have 12 items which I tagged but when running the script I only get the address of 10 of them. Do you know why?
Also, how I can ensure that I don't lose the tags? I guess that unless I modify them they will remain as they were set and with a backup, I will have a copy of them but I would like to check with you first.
Regards,
Check in the log tab
(10.01.2023, 14:44)Daniel Wrote: Check in the log tab
Daniel thank you, the two missing are there!
