Threads: 3
I have an installation with one LM5 and three Ip router, with ZeroTier I can reach LM5 via ETS but I can't program devices. In diagnostic I can't reach any of the devices via individual address but if I scan the line I can definitely see them and bus monitor works.
I know that probably is something simple but I can't figure out what the problem is, any ideas?
Threads: 19
You can only program devices directly connected to LM.
Threads: 3
Is there any way to use LM5 as a gateway to reach ip routers?
Threads: 19
If you change temporarily LM knx mode to tunneling and set connection to your IP router it might actually work. Never tested
Threads: 3
Nope, if I set lm5 to tunnelling I can't even reach it via ETS. I'll do some other tests though.
Threads: 19
Check PM and let me know if it works.
Threads: 3
22.01.2023, 21:26
(This post was last modified: 22.01.2023, 22:01 by Admirim Toska.)
Hello all
I have the same problem... i was programming devices ok until Wednesday 18.01.2023 but now i can not program KNX devices that are connected directly to LM.
Logic machine is online, i can reach it and ETS show Connection on ... only i can not program devices or control group addresses.
Thank you for your help
Admirim
Threads: 32
Check that LM KNX connection mode is set to TP-UART.
Threads: 3
Yes, LM KNX connection is set to TP-UART and i was programing devices for 2 days... until Wednesday 18.01.2023
Threads: 19
Your problem is totally different then the one mentioned above. Check what has changed in your installation since 18.01
