Reactor and power relè card
I wanted to try using Reactor to drive a 4-input power relay board (5 volt powered) as in the attached pictures.
I think I did everything correctly, but it doesn't work: the leds on the board go on and off, but relays dosn't act.
The same board, however, connected to Arduino board works perfectly.
Can you help me?
Thank you
Why did you connect it to 1wire and only partially?
(23.03.2023, 15:15)Daniel Wrote: Why did you connect it to 1wire and only partially?
Actually, as you can see, I connected 5 volts, not 1 wire
This won't work - these relays are meant for 5V operation, LM outputs 24V. Just use normal 24V relays instead.
(23.03.2023, 15:20)admin Wrote: This won't work - these relays are meant for 5V operation, LM outputs 24V. Just use normal 24V relays instead.
OK, thank you!
Peppe
