[RELEASE] LogicMachine firmware 2023.04
LM firmware 2023.04 is ready. This firmware contains minor bug fixes from 2023 RC3.
Video tutorials: https://forum.logicmachine.net/showthrea...9#pid21069
You can find the hardware model in the "Upgrade firmware" window:
[Image: attachment.php?aid=1740]
LM5 Power devices with i.MX6 CPU
LM5 Lite (3 DIN units): image file | signature
LM5 Lite + Ext (4 or 6 DIN units): image file | signature
LM5 Reactor GM KNX: image file | signature
LM5 Reactor GM CANx: image file | signature
LM5 Reactor Dimmer KNX: image file | signature
LM5 Reactor Dimmer CANx: image file | signature
LM5 Reactor IO V2: image file | signature
LM5 M4 (4 DIN units): image file | signature
LM Wall (Ambient V2): image file | signature
Extra packages (i.MX6 CPU)
Devices with old CPU (i.MX28)
LM2 IMX: image file | signature
LM3 V1 (4 x RS-485): image file | signature
LM3 V2 (3 x RS-485 and 1 x RS-232): image file | signature
LM4: image file | signature
LM5 4 DIN units: image file | signature
LM Wall (Ambient): image file | signature
LM Reactor Lite: image file | signature
LM Reactor V1: image file | signature
LM Reactor V2: image file | signature
LM Reactor V3: image file | signature
Extra packages (i.MX28 CPU)
Hi Admin,
Thanks for your and all EMBS team work.
Is it possible have a change log of the updates?
Best regards Cristian
Check changelogs for RC firmwares:
https://forum.logicmachine.net/showthread.php?tid=4424
https://forum.logicmachine.net/showthread.php?tid=4530
https://forum.logicmachine.net/showthread.php?tid=4572
https://forum.logicmachine.net/showthread.php?tid=4637
After upgrading LM5 Lite + Ext (i.MX6) i get no 1-wire tab and the following error:
Resident script:2: module 'ow' not found:
no field package.preload['ow']
no file './ow'
no file 'Library ow'
no file 'Library ow.so'
stack traceback:
[C]: in function 'require'
I have an usb to 1-wire interface
Solved: For LM5 install libow, owserver, luaow and genohm-scada-w1 packages
This is correct, now if LM does not have a real output for a package then it ia not installed. You can install it manually from additional packages.
