Threads: 10
06.12.2016, 16:24
(This post was last modified: 06.12.2016, 16:36 by jetsetter.)
Suddenly, my LM is no longer responding in HTTP requests for opening the visualization or configuration pages.
Pinging the LM IP is responding normally and the scripts I can confrim that also working (i.e. I can receive email notifications on some actions)
Is there a way to try to login another way (telnet etc) in order to try to reboot the LM or I have to do a hard reset (power of)?
Is there any danger to corrupt my configuration??
Thank you in adv.
Threads: 3
I had this issue 1 time, and was unable to make it work again expect by doing a power off.
Corruption data is very unlikely to happend, the only thing that came to my mind will be data loss if you have trends. I think it's 5min between saves on the memory.
Threads: 4
Auto save of trend every 5 minutes is to RAM, the actaul save to SD is as far as i know every 30 minutes.
Depending on the moment of power down it can be max 30 minutes you lose.
This only is the case when there are no other issues causing the http fail to respond, when there is a script or something causing this you might have no trend data from the moment the non responding issue started. No way to tell when you can't see the controller data.
Power down won't make anything different then it already is.
Threads: 22
Might be an SD-card issue, if you still haven't rebooted the device then please contact us via e-mail for further assistance. If remote access is possible then we might be able to backup the data.
Threads: 0
04.01.2021, 12:58
(This post was last modified: 04.01.2021, 12:59 by mseb.)
Hi There,
This post isn't really new, but I got exactly the same behavior.
The LM is responding well to ping, but I have no access to any apps, the KNX gateway isn't responding too
I tried to reset the LM (push button) but didnt changed anyting.
Any idea how i can troubleshoot that ?
Threads: 22
As mentioned earlier this is probably caused by the micro SD card corruption.
Threads: 6
I often stumbled upon the word SD card in the forum, but where is it. Did I miss something in the manual? Or do not all LM models have an SD card?
Threads: 13
All of them have it and it is inside. In LM5 you can open top cover to get to it, all the old ones need the housing to be dismounted.
Threads: 12
Yesterday, 10:33
(This post was last modified: Yesterday, 10:34 by davidchispas.)
It's been a while that something similar happens to me if I access the LM remotely through Https. I can connect and work perfectly, but after a while, it usually happens that it does not load the configuration, I access the page but it does not load the objects and the connection is automatically lost.
I have other computers and I can access without problem, but LM takes a few minutes without connection. I rule out a possible downfall of the network in that sense.
This only happens remotely, locally I don't have that feeling.
Now I did tests for Http, and so far without problems.
Is that also a symptom of SD?
Threads: 13
If it works locally then it is not HW. Check for any errors in the browser console while having it.
