Help with the use of storage.set and storage.get
Hello, I'm testing the use of storage function to first understand it, and then visualize some data with JS functions.
First, I write some data in a variable and I storage it:
data = {1,2,3,4,5,6,7,8}
storage.set('/user/example.lp', data)
Second, I read this data and I log it for viewing the result:
store = storage.get('/user/example.lp', {})
log(store)
After that, I try to view it on a browser console, for which I use custom JavaScript (the first console.log it's to see that is working):
$(function(){
console.log('Hello');
  $.get('/user/example.lp', function(exampleData) {
           console.log(exampleData);
But I received a 404 code for the GET, and it says: Not found.
What am I doing wrong?
I've also tried to explore the user folder with Filezilla, but it's empty.
Thank you for your help.
Use FTP to upload .lp files. Storage is like a database, it does not store data in separate files in the filesystem.
(18.10.2023, 10:09)admin Wrote: Use FTP to upload .lp files. Storage is like a database, it does not store data in separate files in the filesystem.
Understood. How can I do it? I figure this, but I'm not sure It's ok
Write to FTP:
data_ftp = {8,7,6,5,4,3,2,1}
io.writefile('example.lp', data_ftp)
Read from FTP:
data_ftp, err = io.readfile('example.lp')
log(data_ftp, err)
Custom javaScript:
$(function(){
  $.get('example.lp', function(exampleData) {
And the same error code 404, not found. In Filezilla I don't find it.
I tried to look for it in the forum using search, but I didn't find it.
Thank you.
You need to use absolute paths. In Lua code use /www/user/example.lp instead of example.lp. In JavaScript code use /user/example.lp instead of example.lp
Done and it works, thank you!
