Threads: 3
Good morning
I have a question: I am monitoring a device through the LogicMachine device using the bacnet-client APP but I have not been able to generate an alarm that indicates the absence of the baCnet (disconnection of the ethernet cable).
Threads: 29
This app doesn't have any alarm features but if you would use our script solution then you can also see the error.
https://kb.logicmachine.net/libraries/bacnet-client/
Threads: 3
PERFECT!! THANK YOU VERY MUCH.
Threads: 3
Could someone share the BaCnet client file to install on a LogicMachine that does not have internet.
Threads: 29
Which firmware and CPU do you have?
Threads: 29
You cannot install our packages on SE hardware, this is not an app.
