Error linking with bacnet objects
Hello team:
I am working with Bacnet Client APP in LogicMachine, each time I try to link logicMachine Objects with Bacnet Object this error is showed, as you can see in attachment.
Could you tell me?, What it is wrong?
Error:
Device with ID=1 or its object with ID = 1_0 doesn´t exist
bestregards
Roger
How does the object list looks like?
(11.03.2024, 08:50)Daniel Wrote: How does the object list looks like?
I attach it .
best regards
Roger
As this app was created by 3rd party we have very limited options here. I think the app doesn't like the same instance ID being used for different object types.
I would suggest you to use our script solution.
https://kb.logicmachine.net/libraries/bacnet-client/
Use direct connection mode, last example.
(11.03.2024, 09:07)Daniel Wrote: As this app was created by 3rd party we have very limited options here.  I think the app doesn't like the same instance ID being used for different object types.
Thank you very much...
best regards
Roger
