Threads: 7
Hi! I would like to have a control page on mosaic or similar that lets me define the brightness of lights per room. From that page the user can establishes this parameter and from the wall switches I will read it and with one press it will establish the appropriate brightness. Can you recommend where to store that data? Virtual addresses for example?
Thanks !!
Threads: 30
You can just use a virtual object to store the brightness value. An event script attached to your wall switch object which will read your brightness and send it to your room object.
Threads: 30
32/0/0-63/7/255
Threads: 30
It is most likely wrong DPT then the address, Mosaic widgets has predefined DPTs which can be linked.
