07.01.2017, 09:21
There are various examples provided that show we can read from an 3rd tcp device or write to a tcp device. I haven't seen a clear example of two way communication with a device. Take the Denon receiver as an example, http://openrb.com/example-use-lm2-as-tcp...e-theater/
Its clear how this resident script uses an single TCP connection to update an object that shows which Source is selected or the volume level. The Denon is capable handling a single network connection. Which means its not possible to use an event based script for a object that would be used to set the volume of the denon. Given that we cannot create a new connection to the denon, the resident script should be the one that instructs the denon to change its volume.
Thanks,
Roger
Thanks,
Roger
