MQTT-Client script stopped sending Units
I have LM5Lp2 with BluHome-Addon for three FreeAir 100 ventilation devices. I used the Client-Script https://kb.logicmachine.net/integration/mqtt-client/, my configuration as attachement. Initially, MQTT sent units with the measurements, but since some days units are missing. I would like to have the units send again, what have I to do? Thanks!
.txt   mqtt-client 2024-07-18.txt (Size: 3.11 KB / Downloads: 9)
Modified example that will publish value + units:
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158
if not broker then   broker = '192.168.1.101'   function multiply(mult)     return function(value)       local num = tonumber(value)       if num then         return num * mult       else         return value       end     end   end   -- topic to object map   mqtt_to_object = {}   -- optional topic value conversion function   mqtt_to_object_conv = {}   -- object to topic map   object_to_mqtt = {}   units = {}   datatypes = {}   objs = grp.tag('mqtt-control')   for _, obj in ipairs(objs) do     object_to_mqtt[ obj.address ] = obj.name     units[ obj.address ] = obj.units     datatypes[ obj.address ] = obj.datatype   end   objs = grp.tag('mqtt-status')   for _, obj in ipairs(objs) do     mqtt_to_object[ obj.name ] = obj.address   end   grp.sender = 'mq'   require('socket')   mclient = require('mosquitto').new()   mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end   mclient.ON_MESSAGE = function(mid, topic, payload)     local addr = mqtt_to_object[ topic ]     if addr then       local fn = mqtt_to_object_conv[ topic ]       if fn then         payload = fn(payload)       end       grp.write(addr, payload)     end   end   mclient.ON_DISCONNECT = function(...)     log('mqtt disconnect', ...)     mclientfd = nil   end   function mconnect()     local fd     mclient:connect(broker)     fd = mclient:socket()     -- fd ref is valid     if fd then       mclientfd = fd     end   end   mconnect()   function publishvalue(event)     -- message from us or client is not connected     if event.sender == 'mq' or not mclientfd then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ]     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     if value ~= nil then       if type(value) == 'boolean' then         value = value and 1 or 0       end       value = tostring(value) .. (units[ addr ] or '')       mclient:publish(topic, value)     end   end   lbclient = require('localbus').new(1)   lbclient:sethandler('groupwrite', publishvalue)   lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')   -- run timer every 5 seconds   timer = require('timerfd').new(5)   timerfd = socket.fdmaskset(timer:getfd(), 'r') end -- mqtt connected if mclientfd then   mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')   res, lbclientstat, timerstat, mclientstat =       socket.selectfds(10, lbclientfd, timerfd, mclientfdset) -- mqtt not connected else   res, lbclientstat, timerstat =     socket.selectfds(10, lbclientfd, timerfd) end if mclientfd and mclientstat then   if socket.fdmaskread(mclientstat) then     mclient:loop_read()   end   if socket.fdmaskwrite(mclientstat) then     mclient:loop_write()   end end if lbclientstat then   lbclient:step() end if timerstat then   -- clear armed timer   timer:read()   if mclientfd then     mclient:loop_misc()   else     mconnect()   end end
Thanks for the quick reply. I changed the script an restarted it. Now the broker gets no data at all, the log shows:
* arg: 1
  * string: mqtt connect status
* arg: 2
  * bool: true
* arg: 3
  * number: 0
* arg: 4
  * string: connection accepted
* arg: 5
  * number: 0
* arg: 6
  * nil
Did I forget anything?
Values are published only on change. Change any object with mqtt-control tag and the new value will be published.
