add element in a standard widget
how I could add an element (% visualization) on a standard widget (roman blinds move/stop) ? I need to watch the % of opened blind as I can see on the apple home kit, as you undestand I should modify the "Roman Blinds move/stop" to add a percentage visualization
thanks in advance for answering me
ps. I'm not a programmer, only if there's a fast way to do it or if someone could write it for me
(27.09.2024, 16:21)arturfra Wrote: Hi,
I created this widget with widget editor module.
Try if could be fine.
Best regards Cristian
.json   Tapparella_senza_text.json (Size: 1.83 KB / Downloads: 14)
Hi Cristian
it works thanks, but I'd like to re-use the original blind widget because it has an image that show the blind up and down, another thing, how your widget recognize the difference when i click on up or down icon ? I associate the same object... but it works correctly
Hi Cristian
Hi up and down it is the same object, the difference it is the value sent 0 for up and 1 for down.
BR Cristian
Hi Cristian
BR Cristian
ahhh ok tnx, is it possible to invert the % value? Example instead to show 70% close for me better to show 30% open as Apple Home kit does...
Hi Cristian
BR Cristian
Assume that the object of blind positions it is '1/0/0'
And the object that you want to use in apple will be '32/1/1'. I will do:
knx_value = grp.getvalue('1/0/0')
New_value = abs(knx_value - 100)
grp.write('32/1/1',New_value)
It should work, maybe could be others ways to do.
Let me know.
