Jullix
Dear reader,
I want to read an equalizer for the solar panels and battery storage.
I get data in my log via the script below.
json = require('json') ltn12 = require('ltn12') http = require('socket.http') token = 'xxxx' url = 'https://mijn.jullix.be/api/v1/actual/..install number/detail/grid' resp = {} res, code = http.request({   url = url,   method = 'GET',   headers = {     authorization = 'Bearer ' .. token,   },   sink = ltn12.sink.table(resp), }) resp = table.concat(resp) resp = json.pdecode(resp) log(resp)
* table:
["data"]
  * table:
  ["energy_out"]
    * number: 10798.2729492188
  ["captar_actual"]
    * number: 0
  ["meter"]
    * string: E00770007307733
  ["power"]
    * number: 0.189000010490417
  ["energy_in"]
    * number: 16785.4638671875
  ["gas"]
    * number: 0
  ["water"]
    * number: 2088.42895507812
  ["captar_max"]
    * number: 0
["status"]
  * string: ok
How can I get this script so that I can get all the data to a group address?
So also the other links as on this website https://mijn.jullix.be/apidocs/
Thank you!
Here is a code
json = require('json') ltn12 = require('ltn12') http = require('socket.http') token = 'xxxx' url = 'https://mijn.jullix.be/api/v1/actual/..install number/detail/grid' resp = {} res, code = http.request({   url = url,   method = 'GET',   headers = {     authorization = 'Bearer ' .. token,   },   sink = ltn12.sink.table(resp), }) resp = table.concat(resp) resp = json.pdecode(resp) --log(resp) grp.checkwrite('1/1/1', resp.data.energy_out) grp.checkwrite('1/1/2', resp.data.captar_actual) grp.checkwrite('1/1/3', resp.data.meter) grp.checkwrite('1/1/4', resp.data.power) grp.checkwrite('1/1/5', resp.data.energy_in) grp.checkwrite('1/1/6', resp.data.gas) grp.checkwrite('1/1/7', resp.data.water) grp.checkwrite('1/1/8', resp.data.captar_max)
Tnx i gone try
