Edit script but it still run old script
I use a script 1/1/2 to update script of address 1/1/1 example from log(1) to log(2) using those commands:
        db:update('scripting', {script = nScript}, {id = s.id})
        script.disable(s.name)
      script.enable(s.name)
        script.reload()
The update is successful (I see the line log(2) in 1/1/1) but when I change the value of 1/1/1, it still run old script (show 1 in log instead of 2)
How can I fix this? Thank you
Could someone help me please?
Explain your use case. You should not need to update scripts dynamically.
(17.03.2025, 09:25)admin Wrote: Explain your use case. You should not need to update scripts dynamically.
I want my end-user can update the script without any coding skill. Like they can setup a script that turn on Light 1, wait 8 second then turn off Light 2, and they can edit it later when they need. They can do that with only tap/swipe item on visulization and the code will change depend on their action.
Why not use scenes for this?
(17.03.2025, 09:36)admin Wrote: Why not use scenes for this?
Because I think write/read script is faster and more complex than edit/read scene. And sometime I need to check value of a specific address before taking the action. Example, if 1/1/1 = 10 and 1/1/2 = true I will do action A but when 1/1/1 = 10 and 1/1/2 = false I will do action B.
Your client will use objects to insert the values so why do you need to modify the script?
(17.03.2025, 09:42)Daniel Wrote: Your client will use objects to insert the values so why do you need to modify the script?
It's not just about control the device. Example I creat some text Input in the Vis. And maybe they can add the option send email to "abc@gmail.com" with the subject "Something happen" which they can set themself when the object is set to specific value.
String, number - no difference. You still must use a object where your user will type the values and your script will just read this.
(17.03.2025, 09:50)Daniel Wrote: String, number - no difference. You still must use a object where your user will type the values and your script will just read this.
Let say when they want to send the email to 100 user, if I use object or storage to store that value, it's not a wise idea. My Idea is I can use only one object.
Example
The script I want to edit is 1/0/1
1/7/1 will store the email address
When 1/0/1 = 1, they want to send email to "abc", they will set 1/7/1 to "abc", 1/0/1 will be set to 'email("abc")'
then they want to send to another email "abcd"  , they will set 1/7/1 to "abcd" , 1/0/1 will be set to 'email("abc") email(abcd)'
Use this:
scriptid = 23
scriptcode = [[
log('1234')
params = {
  data = {
    id = scriptid,
    scriptonly = true,
  script = scriptcode
webrequest = require('webrequest')
res, err = webrequest('scripting', 'save', params)
(17.03.2025, 10:20)admin Wrote: Use this:
scriptid = 23
scriptcode = [[
log('1234')
params = {
  data = {
    id = scriptid,
    scriptonly = true,
  script = scriptcode
Sadly it didnt work. I also try to run your whole code alone but it the script which has ID = 23 didnt change to log('1234')
Anything in the error log? Which firmware version do you have?
The log said: module 'webrequest' not found:. How can I install it?
I'm using 20210521 FWW
Install 2024 firmware: https://openrb.com/firmwares/
(17.03.2025, 13:27)admin Wrote: Install 2024 firmware: https://openrb.com/firmwares/
Is there any alternate way to do it with http request? I dig a bit and see that I can send http post to "/scada-main/scripting/save" with the payload contain data and script ID. But I dont know how to extractly do that in code. I try some code but get the response (404 Not Found)
