SMS not received
We are using a LogicMachine5 Reactor GSM to send SMS in case of alarm of some variables. The script uses a for to send the message to multiple numbers, with a delay between them. You can see the code below (I changed the phone numbers with generic ones for security purposes).
The problem is that not every SMS is received. What could be causing this? Is there any way to check if the SMS is received?
Thank you in advance,
André Neves
require('user.sms')
Nrs_Tlf={'123456789',
       '987654321',
     '147852369'}
tab = string.split(name, ">")
if value==1 then
    Alarme="Alarme:\n"..tab[2].."\n"..timestamp
elseif (value==2) then
   Alarme="Alarme Reconhecido:\n"..tab[2].."\n"..timestamp
elseif (value==3) then
   Alarme="Alarme Reposto:\n"..tab[2].."\n"..timestamp
if (value<4 and value>0) then
    for i = 1, 3, 1 do
      sendsms(Nrs_Tlf[i],Alarme)
      os.sleep(30)
  log("SMS enviados")
  log("Out of bounds.")
See this post on how to add additional logging to the SMS script:
https://forum.logicmachine.net/showthrea...3#pid38043
