How to purge Data Storage?
Hi, I would like to clean Data Storage.
I know I can use storage.delete(key) but I would do it in a time with a script, without the need to know every single key.
is it possible to do?
Peppe
You can delete everything with a single command but it will also drop configuration for apps that use storage (Mosaic, new Visu etc). Explain your use case for this.
(05.05.2025, 05:28)admin Wrote: You can delete everything with a single command but it will also drop configuration for apps that use storage (Mosaic, new Visu etc). Explain your use case for this.
I will have no problem for apps configuration in this LM right now... I just have so much useless key-value.
But would be nice to can delete the keys by wildcard *
To delete everything from the storage go to Utilities > Reset / clean-up and select "Script and application storage".
Or you can use a script with a wildcard:
keys = storage.keys('values*')
for _, key in ipairs(keys) do
  storage.delete(key)
(06.05.2025, 06:36)admin Wrote: To delete everything from the storage go to Utilities > Reset / clean-up and select "Script and application storage".
  storage.delete(key)
Thanks so much!
