[BETA] LogicMachine firmware 2025.07
LM 2025.07 beta firmware is ready for testing. This version includes many bug fixes and improvements.
Most notable changes:
- Old visualization is disabled for new installations (does not apply if upgrading from anĀ older version or restoring a backup)
- New Visu beta app added
- Added support for new Visu cloud version
- Mosaic app removed
Old visualization and Mosaic can still be used with this firmware. No new features will be added to old visualization and Mosaic. Only critical bug fixes will be provided.
You can find your hardware model in the "Upgrade firmware" window:
[Image: attachment.php?aid=1740]
LM5 Power devices with i.MX6 CPU
LM5 Lite (3 DIN units): image file | signature
LM5 Lite + Ext (4 or 6 DIN units): image file | signature
LM5 Reactor GM KNX: image file | signature
LM5 Reactor GM CANx: image file | signature
LM5 Reactor Dimmer KNX: image file | signature
LM5 Reactor Dimmer CANx: image file | signature
LM5 Reactor IO V2/V3: image file | signature
LM5 Reactor IO V2/V3 + LTE: image file | signature
LM5 M4 (4 DIN units): image file | signature
LM Wall (Ambient V2): image file | signature
Extra packages (i.MX6 CPU)
libmysqlclient has been replaced by libmariadb. No script changes are needed for MySQL/MariaDB connectivity.
(30.07.2025, 10:09)admin Wrote: LM 2025.07 beta firmware is ready for testing. This version includes many bug fixes and improvements.
Thanks admin,
fantastic, a clarification; if I will install new firmware mosaic disappear, but if I will install the ipk it works again, is it? I ask this because until I make the migration I would like use mosaic. Is it possible have the ipk of mosaic?
BR Cristian
Installed app will not disappear. If you do a factory reset then it will be gone but you can install it from the store.
(30.07.2025, 19:03)Daniel Wrote: Installed app will not disappear. If you do a factory reset then it will be gone but you can install it from the store.
Thanks for the answer
