Modbus Register Adresses 65-72 issue
I need and advice with modbus RS485 issue,
Im not able to control addresses 65-72 through group objects, RX TX LED on Slave device flash only when I link our group object to the RTU adress, and it updates to correct value, so register is fine, I'm just not able to rewrite it - LM doesn't allow me to, it won't send anything to the RTU, adresses in Slave device are R/W, I have allowed this GO to write to the bus.
Can we somehow allow Logic Machine to write values to these 7 adreses? RTU Device allows us to control these parameters from modbus. Do we need some kind of script for that?
Thanks!
Post your device profile.
File "List" is manufacturer adress list of Device
Json is mine profile using in LM.
Everything is working fine except for 65-72 adresses.
.pdf   List.pdf (Size: 114.64 KB / Downloads: 3)
.json   GalileoV.1.json (Size: 5.07 KB / Downloads: 4)
The correct field name is writable not writeable.
To avoid such errors use Modbus profiler app: https://forum.logicmachine.net/showthread.php?tid=5911
... Thank You so much I haven't noticed this... Its okay
I'm so sorry x)
