25.04.2017, 11:24
We are happy to announce that RC1 firmware is ready for testing.
Major changes
Virtual objects - additional address range which only exists inside of LM and is not sent to KNX/TP and KNX/IP
Trends - secondary Y axis, trends are grouped by object units
Visualization
- Start/stop object mode
- Improved lost connection detection and reconnect workflow
Schedulers
- Extended event date and holiday matching options
- Added sunrise/sunset mode with additional time offset
Scenes - new module which can be used to create simple object value sequences
Improved performance for certain modules - Reactor line (excluding Reactor V1), EnOcean, BACnet
Other
- Better error log with function call traceback
- Updated translations
- Custom SSL certificate upload
- LM can now act as NTP time server (useful for secure KNX connection where time sync is required between all LMs)
- Removed block editor, please use FBeditor app instead
LM2 IMX: http://dl.openrb.com/lm-17/lm2i-20170424.img
LM3 V1 (4 x RS-485): http://dl.openrb.com/lm-17/lm3v1-20170424.img
LM3 V2 (3 x RS-485 and 1 x RS-232): http://dl.openrb.com/lm-17/lm3v2-20170424.img
LM4: http://dl.openrb.com/lm-17/lm4-20170424.img
LM5 lite: http://dl.openrb.com/lm-17/lm5m3-20170424.img
LM5 lite with extensions: http://dl.openrb.com/lm-17/lm5m3ex-20170424.img
LM5 4 DIN units: http://dl.openrb.com/lm-17/lm5m4-20170424.img
LM Ambient: http://dl.openrb.com/lm-17/lmwall-20170424.img
LM Reactor Lite: http://dl.openrb.com/lm-17/rctl-20170424.img
LM Reactor V1: http://dl.openrb.com/lm-17/reactor-20170424.img
LM Reactor V2: http://dl.openrb.com/lm-17/reactorv2-20170424.img
LM Reactor V3: http://dl.openrb.com/lm-17/reactorv3-20170424.img
Extra packages: http://dl.openrb.com/lm-17/pkg
LM5 Power devices
Note: if upgrade does not work, run this script once:
https://gist.github.com/jsopenrb/4ba040d...dbc6b74447
LM5 lite: http://dl.openrb.com/lm-17-imx6/lm5m3-20170424.img
LM5 lite with extensions: http://dl.openrb.com/lm-17-imx6/lm5m3ex-20170424.img
LM5 4 DIN units: http://dl.openrb.com/lm-17-imx6/lm5m4-20170424.img
Extra packages: http://dl.openrb.com/lm-17-imx6/pkg
Old LM2 with AT91 CPU: http://dl.openrb.com/lm-17/lm2-at91-20170424.img
Warning: only full re-install via UART/TFTP is possible, upgrade via WEB is not supported
http://dl.openrb.com/misc/lm2.flash.pdf
Load balancer FW and packages will be published later.
Major changes
Visualization
Schedulers
Other
LM5 Power devices
