Amazon Echo / Alexa app
All what you see there is how Amazon has defined it. This is not our invention Smile
Daniel,
Alexa is KO since this morning (France) [Image: sad.png]
Jean-Marc
Jean-Marc
It works fine in UK.
This afternoon unable to connect the cloud connection came back in the evening but alexa does not work even by going through the alexa app of the smartphone
Jean-Marc
Daniel
This morning everything went back to normal, I think the problem was at Amazon
Jean-Marc
Jean-Marc
Hello i want to use color temperature object for led strips, but my controller use just C/W ration DTP. 5.001 and Alexa app needs direct temperature in Kelvins.
Can you add there DTP. 5.001 object support, or do you habve any advice how to solve this problem?
Thank you
You need to convert this in to 2 byte unsigned integer
