[OLD] LogicMachine firmware 2017.06
#61
I am struggling with updating, the LM says "Cannot upgrade, firmware image file is invalid".
The reason i want to upgrade the firmware is that the device wont import new addresses from ETS via a ETS export anymore, I need to to that manually (dont know why).
I have tried running the script for updating, but not sure if I am doing it the right way since nothing changes.
#62
(19.10.2020, 10:29)simen@saasprosjekt.no Wrote: Hello,
Your card is probably in read only mode and needs replacement.
What card? The LM was installed 2 years ago, and last week we were going to implement som changes in the KNX group adresses and need those exported to BACnet.
#64
Check that firmware is meant for the hardware that you have
#65
(19.10.2020, 11:49)admin Wrote: Check that firmware is meant for the hardware that you have
It is a LM5 lite from 2018, i have tried all off the LM5 FW, all of them says the same error message a couple of seconds after i try to upload the FW.
#66
LM5 can have either old or new cpu, which fw exactly have you tried?
#67
(19.10.2020, 11:56)admin Wrote: LM5 can have either old or new cpu, which fw exactly have you tried?
turns out i tried the same FW as the product already had installed..  Idea Confused
I tried now with the "pre-release", that seems to be updating now.
Hope this solves the import problem from ETS.
