Pause modbus function
Good afternoon,
I'm looking at the forum how to pause the modbus function.
I have two devices configured through the .json mapping, however I have to punctually perform readings on the same devices manually, there are quite a few readings and here the errors begin ..
Is there any way to pause normal log reading, so I would pause while performing the manual reads, and at the end of the process I would revert to normal.
As always, many thanks in advance!
Best regards,
Alberto.
You should use modbus proxy functions so your script does not interfere with mapper readings: https://forum.logicmachine.net/showthrea...53#pid1953
(26.06.2017, 16:47)admin Wrote: You should use modbus proxy functions so your script does not interfere with mapper readings: https://forum.logicmachine.net/showthrea...53#pid1953
Thank you very much, works great!! Smile
