Threads: 60
Has anyone created a script for the ELK M1 security panel?
Admin is there any example for a non blocking SSL connection?
Is there an example of, 2 ASCII characters, 2-digit checksum. This is the hexadecimal two’s complement of the modulo-256 sum of the ASCII values of all characters in the message excluding the checksum itself and the CR-LF terminator at the end of the message. Permissible characters are ASCII 0-9 and upper case A-F. When all the characters are added to the Checksum, the value should equal 0.
Thanks,
Roger
Here's a basic SSL connection example:
Code: socket = require('socket')
ssl = require('ssl')
ip = '192.168.1.1'
port = 2601
sock = socket.tcp()
sock:settimeout(5)
sock:connect(ip, port)
sock = ssl.wrap(sock, 'tlsv1')
sock:dohandshake()
Checksum calculation:
Code: function checksum(str)
local sum = 0
for i = 1, #str do
sum = (sum + str:byte(i)) % 256
return string.format('%02X', 256 - sum)
Threads: 60
12.08.2017, 23:21
(This post was last modified: 12.08.2017, 23:22 by rocfusion.)
Hi Admin,
Thank you, the checksum function works. I am trying to do the reverse and verify the message received has a valid checksum
local sum = 0
for i = 1, #str do
sum = (sum + string.byte(str,i)) % 256
x = 256-sum
function reversechk(str, cksum)
local sum = tonumber(cksum,16)
log(sum)
for i=1, #str do
sum= (sum + string.byte(str,i))
return string.format('%02X', sum)
local message= '16XK403923611081711000'
local chksum = checksum(message)
log(chksum)
-- chksum is 67
-- so the total message is '16XK40392361108171100067'
local isok = reversechk(message,chksum)
log(isok)
The reversechk function does not return a 0, what am doing wrong? I have the reverse calculation in C code, maybe you can understand what they doing?
Code: Calculate checksum on received and transmitted ASCII string
Example C code program
//INT8U is an 8 bit unsigned integer.
INT8U itAscRecBuf[82]; //ASCII receive character buffer
INT8U AscHexToBin(INT8U, INT8U *); //ASCII hex to binary conversion
INT8U AsciiToHex( INT8U); //Ascii to Hex conversion
//Calculate checksum on a received ASCII string, return checksum value.
//It should equal 0 if good.
INT8U CalcCheckSum(void)
INT8U i,length, cc;
length = AscHexToBin(2, &itAscRecBuf[0]);
//get length value, first two characters
cc = AscHexToBin(2, &itAscRecBuf[length]); //get checksum value at end of string.
for (i=0;i<length ;i++ )
cc += itAscRecBuf[i]; //get string value and add it to checksum
return(cc);
//good checksum should equal 0 }
//ascii hex to binary, width 1 or 2
INT8U AscHexToBin(INT8U Width, INT8U * DataPtr) //
INT8U aVal; // accumulated value
aVal = AsciiToHex(*DataPtr);
DataPtr++;
if (Width == 2) //two digits wide, else 1 digit wide
aVal = aVal << 4;
aVal += AsciiToHex(*DataPtr);
return(aVal);
INT8U AsciiToHex( INT8U Value )
switch ( Value )
case 'A': return( 10 );
case 'B': return( 11 );
case 'C': return( 12 );
case 'D': return( 13 );
case 'E': return( 14 );
case 'F': return( 15 );
default: return( Value - 0x30 );
Thanks,
Roger
You don't need a separate function for this, last 2 bytes of the message is the resulting checksum. You can do it like this:
Code: message = '16XK40392361108171100067'
calccs = checksum(message:sub(1, -3)) -- calculated checksum from message data
recvcs = message:sub(-2, -1) -- received checksum
log(calccs, recvcs)
Threads: 60
Hi Admin,
Thank you, I am trying to get the connection working with ssl, but the connection gets closed. I want to use copas since this gives more flexibility of building a non-blocking solution. I have the option also to run code in separate threads.
Code: if not ready then
socket = require("socket")
copas = require("copas")
require('ssl')
ready=true
esys = {}
local sum = 0
for i = 1, #str do
x = 256-sum
function validchecksum(str)
calccs = checksum(str:sub(1, -3)) -- calculated checksum from message data
recvcs = str:sub(-2, -1) -- received checksum
return calccs == recvcs -- when they the same return true
--helper functions to round and increment values
function increment(n)
n = n + 1
return n
function parse(data)
alert('elk parsing: %s', data)
if(validchecksum(data)==true)then
local response = string.sub(data,3,-5)
alert('elk message is: %s',response)
function sendElk(command)
skt:send(command)
sleep(1)
function init()
alert('running init')
function fromKNX(command)
local telegram = string.split(command,',')
alert('from knx %s',command)
local server = socket.udp()
server:setsockname("127.0.0.1",33456)
function handler(skts)
skts = copas.wrap(skts)
alert("UDP connection handler")
while true do
local s, err
alert("UDP receiving..")
s, erro = skts:receive(2048)
if not s then
alert("UDP Receive error: %s", erro)
break
alert("UDP Received data, bytes: %s",s)
fromKNX(s)
copas.addserver(server, handler, 1)
--[[ co = copas.addthread(function()
while true do
copas.sleep(5) -- wait 5 seconds in case of other events
copas.sleep(-1) -- put the thread to sleep until wakeup is called
end)]]--
if not skt then
-- create tcp client
sslparams = {
mode = "client",
protocol = "sslv3",
key = "crt/ca-key.pem",
certificate = "crt/client.pem",
cafile = "crt/ca-cert.pem",
verify = "peer",
options = {"all", "sslv3"}
skt = copas.wrap(socket.tcp(), sslparams)
skt, err = socket.connect('192.168.0.11', 2601)
-- when theres no error connect ok, initialize
if(not err) then
skt:settimeout(0)
-- add receive thread
while true do
local resp,err = copas.receive(skt)
-- if theres no connection start a new connection
if not resp then
alert("[tcp-client] Receive error: %s", err)
copas.removeserver(skt)
skt = nil
break
if(string.find(resp,'^16XK')==false)then -- don't process timer messages
local fd,prtd = pcall(parse,resp)
if(fd==false)then
alert("Error with parsemsg %s ",prtd)
end)
if skt then
alert('[tcp-client] connection ok')
init()
-- error while connecting,
if warningfailed then alert('[tcp-client] connection failed (conn): %s', err) end
return
alert('[tcp-client] error connecting %s',err)
return
copas.loop()
What am I doing wrong?
Thanks,
Roger
Replace this part:
Code: -- create tcp client
sslparams = {
mode = "client",
protocol = "sslv3",
verify = "peer",
With this:
Code: skt = socket.tcp()
skt:settimeout(5)
skt:connect('192.168.0.11', 2601)
skt, err = ssl.wrap(skt, 'sslv23')
if not err then
skt:dohandshake()
skt = copas.wrap(skt)
Threads: 60
ok thanks, I will try and let you know.
thx
Roger
Threads: 60
Hi Admin,
Ok so with a slight modification its now working, see the revised code below. Question in terms of error handling for the connection will this be sufficient for this client script to reconnect if for whatever reason the connection is lost?
Thanks,
Roger
Code: if not skt then
skt = socket.tcp()
skt:settimeout(5)
skt, err = ssl.wrap(skt,'tlsv1')
if not err then
skt:dohandshake()
while true do
if not resp or err ~=nil then
alert("[elk-client] Receive error: %s", err)
skt = nil
break
if(string.find(resp,'^16XK')==nil)then
if(fd==false)then
alert("[elk-client] Error with parsemsg %s ",prtd)
alert('[elk-client] time message: %s', resp)
end)
alert("[elk-client] connection error: %s", err)
skt = nil
return
Threads: 60
(19.08.2017, 23:32)rocfusion Wrote: Hi Admin,
Thanks,
Roger
skt = socket.tcp()
skt:settimeout(5)
if not err then
skt:dohandshake()
while true do
skt = nil
break
if(fd==false)then
end)
skt = nil
return
Hi Admin, is this ok?
Thx
Roger
