Auto OFF function
Hello All,
I'm searching for a small script, which switches off a power plug if device in stanby mode for a long time.
For example I'm using MDT AMS16.12 with power measuring function. The TV is connected to the power plug, which is controlled by AMS1216 device.
So after watching TV I forget sometimes to disable the plug.
I looking for a script like:
if TV power plug status =1, but power consumption < 10W for 1 hour,
then disable the plug.
Tried to use FBD editor of WISER, but without succes. Please
advise.
Hello.
Here is the resident script, which will be executed every minute
if not minute_counter then   minute_counter = 0 end plug_status = grp.getvalue('plug_status') -- the object of plug status power_consumption = grp.getvalue('power_consumption') -- the object of power in watts log(minute_counter) --log(plug_status) --log(power_consumption) if plug_status and power_consumption < 10 then   minute_counter = minute_counter + 1 else   minute_counter = 0 end if minute_counter > 59 then -- one hour passed   grp.write('plug_control', false) -- turn off plug (plug control object)   minute_counter = 0 end
Thanks a lot, your script is working perfect!
