email with attachement gives image size 0
#21
(15.08.2019, 14:07)admin Wrote: Log what output the server produces. Add this to the end of the script:
log(image, err, hdrs)
Hi!
I´m doing the same code with another IP camera (hikvision) that allow digest and digest/basic but doesn´t work:
This is the result:
[quote pid="13765" dateline="1565878076"]
[/quote]
* arg: 1   * string: <!DOCTYPE html> <html><head><title>Document Error: Unauthorized</title></head> <body><h2>Access Error: 401 -- Unauthorized</h2> <p>Authentication Error</p> </body> </html> <!DOCTYPE html> <html><head><title>Document Error: Unauthorized</title></head> <body><h2>Access Error: 401 -- Unauthorized</h2> <p>Authentication Error</p> </body> </html> * arg: 2   * number: 401 * arg: 3   * table:    ["server"]     * string: webserver    ["content-type"]     * string: text/html    ["connection"]     * string: close    ["date"]     * string: Mon, 13 Mar 2023 10:37:01 GMT    ["x-frame-options"]     * string: SAMEORIGIN    ["www-authenticate"]     * string: Digest qop="auth", realm="IP Camera(F0849)", nonce="5a6d566c5a475a6d59324d365a474534596a67794d6d493d", stale="FALSE"    ["content-length"]     * string: 178
Thanks!
If it allows basic auth then try using it first.
