FTP create and send
Hello, can you help me with something simple, like creating a file in *.txt or *.csv
1. The name of the file is the date and time to be sent.
2. The content of the file is the date and time of a variable.
3. That it can be sent using FTP.
Thank you very much.
See this.
https://kb.logicmachine.net/scripting/ex...-hour-csv/
Hi, do you know how I can consult (from another device) files that I have created in the local FTP folder of the LM?
What should be the correct syntax?
You can use ftp.get: https://lunarmodules.github.io/luasocket/ftp.html#get
Explain your task, maybe there's a better/easier solution.
