Doorbell 2N IP (Intercom)
I am a novice in scripting.
Is there Anyone that can help me in reading out my doorbell status to link to object in KNX?
My Dorrbell is the 2N IP Verso and it has its own HTTP API (Testtool).
I need the status of the relay switch or the validation of the rfid card. Both would work.
My goal is following problem:
If the relay switch status of the doorbell turns to 'true' then the knx group adresss (boolean) should write to 'true'.
I can start with "https://<ip-adress>/api/switch/status?switch=1"  an request from the doorbell. The doorbell uses TLS and the type "digest" for https.
The response is:
  "success" : true,
  "result" : {
    "switches" : [
        "switch" : 1,
        "active" : false,
        "locked" : false,
        "held" : false
With the automation manual for the http request it is possible to send an request from the doorbell.
https://wiki.2n.com/hip/auto/latest/en/4-akce-action
Is there already a solution for my question/problem?
Thanks!!
I've got my solution:
I activate the remote service and use the remote http code:
"https://remote:remote@192.XXX.XX.XX/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=1/1/2&value=true"
I just used it in the automation of the 2N IP Doorbell. Just stupid i am.
How simple...
Works fine for me!
(30.01.2022, 13:23)KNXSeb Wrote: I've got my solution:
How simple...
Works fine for me!
Hello there! I am trying the same but without success
What i am missing?
Did you enable remote services and did you export the object you are trying to write too?
Also enable Send Basic auth header in Remote services.
(30.06.2025, 07:46)Daniel Wrote: Did you enable remote services and did you export the object you are trying to write too?
Yes, the point is the url works in a browser, then the LM works.
But i cannot make it works from 2n sending the http requests....
Then you should contact 2N for support.
I would make it a GET request and put the text part after the URL
(30.06.2025, 11:05)Erwin van der Zwart Wrote: I would make it a GET request and put the text part after the URL
I Would try! Thankyou all!
